HEC-RAS in Three Dimensions
The wait is over! Finally the official release of HEC-RAS Version 5.0 is here. You can download it from the HEC website at http://www.hec.usace.army.mil/software/hec-ras/
If the download from the HEC website is slow, you can also download it from here:
http://drive.google.com/file/d/0B0bpiyLiUeRXTy1pdUNralMzZ1U/view?usp=sharing (207 MB, Installation package without example problems)
http://drive.google.com/file/d/0B0bpiyLiUeRXNGllMlE5V1dmQmM/view?usp=sharing (538 MB, Installation package with example problems)
This new version also comes with updated manuals (User’s Manual, Hydraulic Reference Manual, and Applications Guide), as well as a new 2D Modeling Manual.
Enjoy and good luck!!!
Stéphane GAIJI
on March 4, 2016Finally … These last days I was beginning to despair
Mikołaj Olbrych
on March 4, 2016Hello Stephane and Chris 😉 I will test it with my current embankment breach project
Unknown
on March 4, 2016I have noticed that I am unable to run any HEC-RAS version beyond 4.1 (all of the beta versions as well as this version 5.0) when I have FLO-2D installed on the same computer. When running HEC-RAS, this error occurs, "HEC-RAS cannot start because there are hdf5 libraries in your Windows system folder(s). It is poor practice to copy application libraries into the system folder because of the order that Windows loads libraries used by programs. Delete hdf5*.dll files from:
C:Windowssystem32
C:WindowsSysWOW64
And then start HEC-RAS again.
HEC-RAS will now exit."
If I follow these instructions, RAS will work but FLO-2D will not.
Currently our solution is to run one software on the main computer and run the other on a virtual machine.
arkads1
on March 4, 2016Hi all. I used the last beta in my last job
Gerinc
on March 5, 2016Nice!
Phuong Mai
on March 6, 2016Nice stuff! Thank you for the post.
I have a quick question – We should have depth-vs-time graphs everywhere within a rain-on-grid 2D domain area, even few millimetres, but why there are many points we just have ZERO depth graphs?
Martin Maretta
on March 7, 2016Nice. Do you plan to publish EA benchmark test?
cy
on March 7, 2016Were there changes from the Aug 2015 beta to the final release?
cy
on March 7, 2016Were there changes from the Aug 2015 beta version to the final release?
Chris Goodell
on March 7, 2016Yes. A few new items, but mostly bug fixes and an improvement to the full momentum solver for 2D.
Chris Goodell
on March 7, 2016No, but HEC might.
Chris Goodell
on March 7, 2016Not sure. I haven't tested that yet.
Phuong Mai
on March 7, 2016Just found the answer. Go to RAS Mapper/Tools/Render Mode Options, then select Horizontal (As computed), set Plot Tolerance to zero, we can see the water everywhere in the 2D domain! Chhttp://hecrasmodel.blogspot.com/logout?d=http://www.blogger.com/logout-redirect.g?blogID%3D1675184707067447729%26postID%3D636433072087455954eers.
Eric
on March 9, 2016When I open up the geometric data editor it now has a grid of numbers completely covering the model extents, and I can't figure out how to turn the numbers off. I turned everything off in View Options and that didn't do it. Any thoughts; what am I missing?
Chris Goodell
on March 9, 2016Could it be a map layer in the background images? Other than that and the view options, not sure why that is happening. Do you know what the numbers represent?
Eric Clyde
on March 10, 2016It appears to be associated with the terrain, but I have been working with this same terrain and project for months with no similar problem.
Margaretha Titi
on March 16, 2016Hello Chris, can I install this 5.0 final along with the previous beta or 4.1 in the same drive C?
Thanks for answering and have a good day!
Chris Goodell
on March 16, 2016Yes. I have 4.1 and 5.0 on my computer. Both work. I think you can even have the beta version on there with 5.0.
h2othomas
on April 5, 2016Are there issues with installing on Windows 10 Pro? Thanks!
h2othomas
on April 6, 2016Hi Chris, are there any issues with Windows 10? Thanks!
Chris Goodell
on April 6, 2016I don't know of anything specific. But what I do know is that HEC did not test RAS 5.0 with Windows 10. So there are likely to be some quirks, at the least.
Stéphane GAIJI
on April 7, 2016HECRAS 5 work fine on my Windows 10 Home
Phuong Mai
on April 7, 2016I've installed it onto my Windows 10 Pro machine, and haven't found any issues so far.
Roi FACAL VAZQUEZ
on October 20, 2016same error
Rohit
on May 2, 2018Hi Chris, Just installed 5.0.4, all works fine but unable to open RAS Mapper although 5.0.3 version is working fine. I have Win 7, is anyone here facing same issue?
Chris Goodell
on May 3, 2018That’s not good! You may want to let HEC know if you can’t resolve the issue.
