HEC-RAS 5.0.4 is released!
Written by ironcore | May 3, 2018
Message from HEC on the new release of HEC-RAS version 5.0.4.  Make sure to also check on the new Verification/Validation and the Benchmarking documents.
***Note.  If you originally downloaded 5.0.4 before May 4 at 4:00 pm PDT then please redownload and install from the links below.  There were some minor errors found in the original release.
Download HEC-RAS Version 5.0.4 here:
Download RD-52  HEC-RAS Verification and Validation Tests document here:
Download RD-51 Benchmarking of the HEC-RAS Two-Dimensional Hydraulic Modeling Capabilities here:
There are several other new useful documents related to HEC-RAS here:
From HEC:
We have released the final version of HEC-RAS 5.0.4 today.  It is now available for download from our webpage at the link below.  I have enclosed the 5.0.4 release notes for your review.  I have also included a separate document that describes how to use the new features contained in this version. Additionally  I have also included a document on how to spec out a computer for doing 2D modeling with HEC-RAS.
We hope you enjoy the new version of the software.  As always, please keep us informed on any bugs you find, or your ideas for new features.  Here is the link to the HEC-RAS 5.0.4 web page:
The following is a list of the major new features you can read about in the Release Notes and the Supplemental User’s Manual:
  1. New RAS Mapper Pre-Processor Tools
  2. Variable Time Step Capabilities (improved accuracy and faster run times)
  3. Increased Computational Speed for 2D Computations (2 to 5 times faster run times)
  4. Enhancements to SA/2D Hydraulic Connections
  5. New 2D Polygon Mesh Refinement Tool
  6. Internal Boundary Condition Lines for 2D Areas
  7. New Velocity Term for 2D Flow Area Boundary Conditions
  8. 64–bit Version of RAS Mapper and 64-bit 2D Pre-Processor (RAS now can handle much larger 2D models)
  9. Improved Terrain Generation Utility
  10. Improved Manning’s n Layer Development
  11. Sediment – New Options in the User Defined Grain Class Editor
  12. Sediment – New Transport Function Calibration Options
WARNING: Some of the bug fixes “may” cause the computed results from 5.0.3 to 5.0.4 to change.  Please read the Release Notes carefully for information about these changes.
There are two new verification and validation documents for HEC-RAS now available on our web page in the HEC-RAS area.  Here is a short description of each:
  1. RD-52  HEC-RAS Verification and Validation Tests (Enclosed in this email)
            This is the first ever full blown Verification and Validation document for HEC-RAS.  In this report we compare HEC-RAS to: analytical and text book data sets; lab studies, and real world flood events with good observed data.  This report covers 1D steady flow; 1D unsteady flow, and 2D unsteady flow computations.  The report verifies that HEC-RAS correctly solves the equations used in each of these computational frameworks, and it verifies that HEC-RAS can be used for a very wide range of riverine modeling conditions.  It can aslo be download here:
  1. RD-51 Benchmarking of the HEC-RAS Two-Dimensional Hydraulic Modeling Capabilities
This research document summarizes how the Hydrologic Engineering Center’s (HEC) River Analysis System (HEC-RAS) software performed in the two-dimensional (2D) modeling benchmark tests developed by the United Kingdom’s (UK) Joint Defra (Department for Environmental Food and Rural Affairs) Environment Agency.  This is an updated version of this report that we previously developed.  We re-ran all of the test, plus one new test, with version 5.0.4 of HEC-RAS.  The results are even better than before, and the HEC-RAS computational speed is much faster than previously document.  This report can be downloaded from our web page at the following link:
  1. Anonymous
    on May 3, 2018
    Brilliant, looking forward to giving it a try.
  2. Stéphane GAIJI
    on May 5, 2018
    After downloading, I think that we have to desinstall the "old" one and then reinstall the "new one" ? Right ?
  3. Chris Goodell
    on May 5, 2018
    No, you can keep the old one.
  4. Habtom Mulugeta
    on May 6, 2018
    Dear HECRAS users I download the new vesrion HECRAS 5.0.4, but while try to open the RasMapper wizard its not open, anyone who knows how to fix this thing please share me your idea.
    Kind regard,
    Habtom Mulugeta
  5. Habtom Mulugeta
    on May 6, 2018
    Dear all, Do any one face with difficulties to open HECRAS Ras-mapper wizard in the new version of 5.0.4?
    Regards,
    Habtom Mulugeta.
  6. Chris Goodell
    on May 6, 2018
    Not me. I've used it on 2 different Windows 10 computers without problems.
  7. Alberto Blanco
    on May 8, 2018
    Dear Habtom, It happens the very same thing with my laptop running on Windows 8. RasMapper simply just does not react. Problems with the "Microsoft .NET Framework 4.7.1 Full" may be? Don't know.
    Regards
    Sixto Blanco
  8. Alberto Blanco
    on May 8, 2018
    Regards
    Alberto Blanco
  9. Habtom Mulugeta
    on May 8, 2018
    Dear, I think Ras mapper of version 5.0.4 HECRAS, has some difficulties to open the wizard at windows 7 computer, if there is any solution for that please let me know.
    Thanks in advance.
  10. HER
    on May 9, 2018
    I'm using this new version for flood mapping, but I'm having a hard time of importing the breaklines shapefile to the 2D flow area since the Breaklines Coordinate Table under the Breakline of GIS Tools is not yet activated unless i will draw a breakline for it to activate.
    Hope you can address this question.
    Thanks in advance.
  11. igorshev710
    on May 10, 2018
    I have the same problem on win7 64-bit computer. But on the win8.1 64-bit computer RasMapper works fine.
    I start HEC-RAS, but RasMapper window doesn't open. The previous version works fine. Maybe new RasMapper requires some libraries which win7 doesn't have?
  12. igorshev710
    on May 10, 2018
    I have the same problem on win7 64-bit computer. But on the computer win8.1 RasMapper works fine. And it works fine on the another win7 64-bit computer.
    The previous version of HEC-RAS works fine on the all. Maybe new version of RasMapper requires some different libraries then previous version? And one computer doesn't have them. But I don't know what?
  13. Unknown
    on May 10, 2018
    Hello Chris. I'm Alberto from Chile (UCSC Class). I have the same problem, I can not open ras mapper in Windows 7, both for new or old projects.
  14. Alberto
    on May 10, 2018
  15. Anonymous
    on May 11, 2018
    I built a 2D model in RAS 5.0.3 and run well. For test purpose, I open the model in Beta RAS 5.0.4, and the model run fine. However, as I open the model in RAS 5.0.4, the geo, flow and plan files look fine. when I start running the model, it gave an error "Mesh '2Darea' was not created successfully". I went back to geometry editor of 2D area, when i start moving points, it gave "Unknown error: Arithmetic operation resulted in an overflow"; I move a 2d cell point for test, it gave "3 face errors detected on the perimeter of the mesh" which i couldn't identify where the errors are like it was shown as red dot in 5.03 and beta 5.04. As i pan around, the number of errors keep changing but not shown in the editor window. Has anybody seen this error before? Thanks for any help!
  16. Alberto
    on May 11, 2018
    Hello Chris. I'm Alberto from Chile (UCSC Class). I have the same problem, because I can not open RAS MAPPER on Windows 7 computers. I have tried it with three PCs and I have the same problem.
  17. Chris Goodell
    on May 15, 2018
    Sounds like 5.0.4 has some bugs. If you can get a Windows 10 machine, try it there. Otherwise, you may be stuck with the older RAS version until they fix it.
  18. Unknown
    on May 16, 2018
    I have the same problem on win7 32bit computer. Does anyone have any ideas? tks.
  19. Domenico Impagnatiello
    on May 16, 2018
    I have the same problem on windows7 32 bit machine. Does anyone have any ideas? Tks
  20. Anonymous
    on May 17, 2018
    Is there an option to perform sediment transport in HEC-RAS 2D yet? I thought that was going to be an option on the new version.
  21. Chris Goodell
    on May 17, 2018
    RAS Mapper in 5.0.4 is now exclusively 64 bit. So if you have a 32 bit computer you’ll unfortunately have to use 5.0.3
  22. Chris Goodell
    on May 17, 2018
    No. Not yet. It’s probably a few years out still.
  23. sss
    on May 19, 2018
    I am reading HEC-WAT user manual now. In bench mark 5 it is presented about computational interval. In the manual we can not see much effect from computational interval there. But in my case WSE and velocity change when I change the computational interval n considerable amount while I was using HEC 5.0.3. How to select a reasonable computational interval?
  24. kiran shrestha
    on May 21, 2018
    hec ras automatically close do you have any solution for this?
  25. kiran shrestha
    on May 21, 2018
    hec ras automatically close every time when using this software. what is the solution of this problem?
  26. Stéphane GAIJI
    on May 21, 2018
    Have your à 64 bits system or only 32 bits system ? The new RASMapper release work on 64 bits system.
  27. Alberto
    on May 25, 2018
    Hello, With windows 7 updated I have no problems!
  28. Anonymous
    on May 29, 2018
    I am looking forward for the 2D sediment capabilities of HEC-RAS too. Hope it does not take HEC too long to release.
  29. Davis Murphy
    on July 18, 2018
    I had a similar issue that I solved recently. RASMapper seemed to be displaying where the face connection errors were located (although erratically). So, I went through and corrected errors as they showed up within RASMapper. This actually didn't seem to correct the problem, but later I replaced all of the GIS outline points in the 2D flow areas editor using excel data formatted as data type "Number." Once I replaced the GIS outline vertices the Geometry Editor immediately recomputed and loaded the 2D mesh without any issues. Unfortunately, I'm not sure which correction caused the desired result, but I am inclined to think it may have been the GIS outline data since Arithmetic overflow errors seem to be related to programs expecting certain data types (like Float) and getting some other data type (like Text) instead.
  30. HER
    on August 8, 2018
    I would like to know if there is a standard overall accuracy for the flood maps generated using HECRAS or the USGS set a standard for the overall accuracy of the flood maps generated using HECRAS. What must be the minimum values of the overall accuracy for flood maps? I will be glad if someone can send me an RRL regarding this one because I've been searching it and i have still nothing to find.
  31. Unknown
    on August 16, 2018
    After a successful run of HEC-RAS 5.04, the Depth, Velocity and WSE layers do not appear on the RAS Mapper screen even though they are written in the results tab of the RAS Mapper window. Can anyone help on this?
  32. Ramiro Mansilla
    on August 27, 2018
    Hi, i'm using hec ras 5.0.5 and when i want to use the ras mapper function i can't. I simply press the icon but it does not display the menu. Any solution for this? Thanks!!
  33. Hiz
    on August 29, 2018
    Win 7 64 & 32 bit can't run ras mapper 5.0.4 & 5.0.5??
  34. greeshma Ranjith
    on October 4, 2018
    hi i am using hecras 5.0.4, in geometry editor it shows face error detected on the perimeter. i tried cell center movements but cant rectify. can u pls help??
  35. Unknown
    on October 7, 2018
    Hi, i`m using hec ras 5.0.4 and when i want to use the ras mapper function i can`t. when i press the icon it does not displey the menu. Win 8 64x. any solution please
  36. Chris Goodell
    on October 9, 2018
    Have you tried using the new version 5.0.5?
  37. Fatkhur
    on October 10, 2018
    I am using hecras 5.0.5 in win 7 64bit, microsoft net framework 4.7.2, Ras mapper cannot function. any solution please
  38. clipping path service
    on November 24, 2018
    Thanks for sharing, this is a fantastic post.Really thank you! Awesome.
  39. Abdul Hasyim
    on January 5, 2019
    Hi, i`m using hec ras 5.0.6 and when i want to use the ras mapper function i can`t. when i press the icon it does not displey the menu. Win 8 64x. any solution please. . . .
  40. Anonymous
    on January 15, 2019
    yes same issue RAS mapper not working on windows 10 64-bit
  41. Unknown
    on March 18, 2019
    KHALID , I WANT TO INSTALL HEC RAS ,HOW CAN IT BE DOWNLOADED
  42. Sifiso
    on June 25, 2019
    I just installed HEC RAS 5.0.6 on windows 10 Machine and RAS Mapper window is not opening . Please assist
  43. Chris G.
    on June 26, 2019
    I assume you have a 64 bit machine? Why not install Version 5.0.7. It's the newest.
  44. Unknown
    on September 2, 2019
    some answer or solution to fix the not open window of mapper?
