HEC-RAS in Three Dimensions
An off-channel storage area in HEC-RAS can be a very useful way to simulate flooding in interior areas, adjacent ponds and lakes, urban areas next to rivers, green storage, or just about any area that you expect to flood but will be better represented as ponded water versus actively conveying water. Connecting rivers to off-channel storage areas is done via lateral structures. Although it is possible to use lateral structures and storage areas in steady flow modeling, typically lateral structures and storage areas are used in unsteady flow modeling, where quantification of storage and hydrograph attenuation are very important.
The River, Reach, and HW RS (Headwater River Station) define the location of the lateral structure in your system. The upstream end of your lateral structure will be located at the HW RS (but can be shifted downstream of this station in the weir/embankment editor). Notice that lateral structures are stationed from upstream to downstream (i.e. 0 is the most upstream point on the lateral structure). The vertical lines in the graphic represent cross sections that are spanned by the lateral structure. The vertical line that sits at station 0 is the HW RS. The boxes on the bottom of the vertical lines represent the invert elevation of the respective cross sections, and the boxes on the top represent the end points of the cross section (on the side of the cross section that the lateral structure is located: left or right). The red dots represent the bank stations of the respective cross sections.
Next, give a description for the lateral structure in the Description box and then define where its headwater position is. You can place the lateral structure in either of the overbanks (left or right side) or adjacent to either bank station (left or right).
The plan data Optimization button is just a shortcut to the plan file to quickly define whether or not you want to optimize the flow split over the lateral structure during the initial conditions run. Typically you will want to optimize this if you have flow over the lateral structure at the beginning of the simulation. If your initial conditions are below the lateral structure, leave this off. The Breach button is a shortcut to the breach editor, if you want to breach this lateral structure during the simulation.
The “Tailwater Connection” is really the subject of this post-this is how you connect the river to the storage area. Make sure you select “Storage Area” as your Type and then go choose the storage area you want to connect to by clicking the “Set SA” button. Alternatively you could connect a lateral structure to another river/reach or you could connect it to nothing (send the flow over/through the lateral structure out of the system).
There’s still work to be done to define the Weir/Embankment (if not already done), but the Storage area and the river are now connected via the lateral structure. If you want to make sure you are connected, look at the points of the lateral structure on the geometry schematic. If you see thin black lines connecting the end of the lateral structure to the storage area, then you know RAS recognizes them as being connected (sometimes you have so zoom in close to see the “connection lines”).
If you are having difficulty connecting lateral structures to rivers and/or storage areas, I highly encourage you to open up this example in HEC-RAS and have a look around. Normally you will find the example projects in C:Program FilesHECHEC-RAS4.1.0Example Projects.
The “4.1.0” might be different if you’re using a different version of HEC-RAS. If you don’t see the example projects here, go to the Help menu item on the main HEC-RAS window and select “Install Example Projects…”
gsharif
on November 8, 2012Thanks chris, although I did something similar like this but using steady flow modelling, but i will go over with the example you mentioned and the notes in depth and will get back to you if get stuck! Thanks again – Sharif
on November 8, 2012Sharif, you're welcome. Yes, you're not going to see much with lateral structures and storage areas in steady flow. Those are much more useful in unsteady flow modeling.
Good luck!
Yashodhan Joshi
on September 22, 2013Can you tell me if this is possible by constructing a channel at right angle with the direction of flow? what would be the changes in surface profiles?
on September 23, 2013Yes. You could do this with a junction (diversion junction) or with a lateral structure connected to a separate reach. Either way works. RAS will not explicitely account for the momentum loss in turning flow 90 degrees to exit through the diversion channel, so you need to account for this with the discharge coefficient or with n values (or both).
ΠΑΡΑΣΚΕΥΗ ΓΙΑΝΝΙΟΥ
on December 10, 2015Hello!
I am trying to run a simulation with a levee and I used the lateral structure and the Storage areas. I have done everything you mentioned! My only problem is that I cant see the flooding water in the storage areas when the average height of the weir is exceeded. The floodplain is generated up to the end of the cut lines.
Can you please help me?
Thanks in advance.
Chris Goodell
on December 10, 2015Check your TW connection. Also, make sure your model is not going unstable. Make sure your timestep is not too large or your n values too low.
Unknown
on February 10, 2016Hi,
I am trying to model the effect of a canal in a system. I have added a storage area which represents the canal. I have used lateral structures and connected these into the storage area. When I model unsteady flow through the model, no water seems to be entering the storage connections and it is producing ridiculous results with water levels of about 30 m. Not sure what I am doing wrong or whether I am missing out a crucial step?
Thanks in advance
Chris Goodell
on February 10, 2016Sounds like your model is unstable. Make sure that at the beginning of your simulation, the water level is low enough so that it is not overtopping the lateral structure. That will help stabilize your model for initial conditions. Also, make sure your cross section spacing and time steps are appropriate and your n values aren't too low. Make sure you have a reasonable lateral structure coefficient (i.e not too high).
on August 25, 2016Hello,
I'm trying to route water from a cross section to a storage area via a pump. I'm setting the "highest elevation in pump line" to the top of the cross section and the storage area has the same min. and max. elevation as the cross section. The model keeps wanting to raise the initial elevation of the storage area beyond the dimensions I've given. Do you know whether the model isn't made to do this or what might be causing this?
Chris Goodell
on August 25, 2016Storage Areas have no maximum stage. As long as water can get to them, they are able to continue filling up. The model is made to work as you wish it to, but make sure you are accounting for all water coming into and out of the storage area.
on August 25, 2016The weird thing is, the storage area is only connected to that one river station through the pump and I've set up the pumps (water surface elevation triggers) to not turn on at all to test the storage area elevation. Even without any water going to it, the model still wants to raise the initial elevation of the storage area.
Chris Goodell
on August 25, 2016That is weird. I would be happy to take a look at it to see what's wrong if you want to send me your model (.prj, .p##, .g## and .u## files). [email protected]
on August 25, 2016I greatly appreciate that. Let me put together my file and anything else you might need to know into an email to send over.
Unknown
on June 12, 2017Hello, I am trying to connect a 2D flow area to a reach with a lateral structure. The lateral stucture intersects several cross sections over a distance of 2000 meters. My cross sections are well defined, but the HW connections don't compute all of the cross sections. The HW connections are blocked between the first two XS with a distance of 2000 meters between those (instead of 200 meters). Any idea to detect all of the XS in HW connections ?
Victor Mars
on March 28, 2018Hello,
I would like to know more about the tailwater connection type 'Out of the system". Does this type of connection mean that as soon as the water flows over the lateral structure, it "disappears" from the system ?
I ran a 1D test model to experiment this connection and I am a little bit confused when i look at the results.
In my model, the water is still flowing over the structure and flooding the part of the XS behind the structure. However, when I look at the Stage and Flow Hydrograph, i can see that my flow leaving is equal to the difference of my upstream volume minus my downstream volume.
I don't know if I have been clear but I would just like to know a bit more about how is this type of connection working and what's happening in HEC-RAS when you're using it.
Thanks a lot in advance and thank you for this website who helped me so many times.
Chris Goodell
on April 5, 2018Yes, flow over the structure is computed by the capacity of the features on the structure itself (weir, culvert, gates, etc) without consideration of tail water effects. The flow will leave your reach and disappears.
Segolene
on June 6, 2018Hello,
I also wonder about the "Out of the System" tailwater connection type.
My model is a steady flow modeling, with one unique chanel.
The flow injected uspstreeam into the model is 70 m3/s.
I have leaving flow at the lateral structure (Q=5 m3/s) but I still have 70 m3/s in the cross sections downsteam of the lateral structure.
I don't undersatnd why do I still have 70 m3/s downstream of the lateral structure with "Out of the System" connection. Do you have an explanation about this problem?
Thanks a lot in advance.
