Vertical Walls | Kleinschmidt
Vertical Walls-What are the Implications?
Many water surface profile software programs prior to HEC-RAS had a quirky rule against having perfect vertical sides.  In other words, you could not have two or more elevations at the same stationing.  A perfect example of this is a rectangular flume.  The workaround for the older software was to define the tops of the […]
Read More
