text file | Kleinschmidt
HEC-RAS File Types
Behind the scenes, HEC-RAS automatically creates a series of input and output files when working with a model. It is important to know what each of these files does and how they fit into the overall scheme of your project. Keeping track of these files in an organized manner is good practice, especially as your […]
Read More
Permanent and Non-Permanent Ineffective Flow Areas
The traditional way of changing non-permanent ineffective flow areas to permanent involves going through each cross section, one at a time, in the cross section editor, selecting Options…Ineffective Flow Areas, and then manually checking which ineffective flow areas to make permanent. This can be long and tedious if you have a lot of cross sections […]
Read More
