Station-Elevation Points | Kleinschmidt
Deleting Portions of HEC-RAS Cross Sections Quickly
Ahead of the wide-scale implementation of the 2-dimensional (2-D) modeling module in HEC-RAS, I wanted to share a quick tip that will be useful for editing your 1-dimensional (1-D) HEC-RAS model to prepare to couple your 1-D channel with a 2-D overbank area. It’s common to have a cross section with a well-defined channel and […]
Read More
Exploring HEC-RAS: XS Interpolation Within a Reach
I’m starting a new series called “Exploring HEC-RAS”.  Each post will discuss a feature in the menu items, starting with the Tools menu item in the Geometry Schematic.  Today’s topic is “XS Interpolation Within a Reach”. There are two options for interpolating cross sections in HEC-RAS:  “Within a Reach…”, let’s call this Option A, and […]
Read More
Cross Section Points Filter
As RAS model development is done more and more through GIS, using the HEC-GeoRAS extension, cross section point filtering is becoming a standard part of the HEC-RAS model development exercise.  It’s not too uncommon for a model created in GIS to have multiple hundreds of cross section station elevation points.  This is normally not a […]
Read More
I am working on a dam breach project where I’m trying to simplify a complicated model with dozens of tributaries and storage areas. In the process, I’m converting a few tributaries into storage areas (which are surrounded by other storage areas). For example, I want to convert the reach below (from 5.43 to 0.55) to […]
Read More
Written by Chris Goodell, P.E., D. WRE | WEST ConsultantsCopyright © RASModel.com. 2010. All rights reserved.Now that a lot of us use GIS to generate our cross sections, this is becoming a much more “used” feature in RAS: The Cross Section Points Filter. RAS allows a maximum of 500 station-elevation points in any given cross […]
Read More
