Overflow Gates
In modeling irrigation canals in HEC-RAS, a typical structure that is encountered is a check gate. Check gates are designed to back the water up behind them in an effort to keep the water level immediately upstream of these gates at a constant level. As the flow rates change in the canal, the gate openings […]
