Inline Structure | Kleinschmidt
Rating Curves for Dams
Version 5 of HEC-RAS allows the use of rating curves for inline structures (and lateral structures).  Rating curves can be added through the Outlet RC feature in the inline structure editor.  Inline structure rating curves can be useful for evaluating the impacts of structures, such as labyrinth dams, where it may be difficult to correctly […]
Read More
Time Series Outflows for Dams
Want to simulate a time series of outflows for a dam?  It’s easy.  In Version 5.0.3 there’s a new feature called Outlet T.S. (Outlet Time Series) in the inline structure editor.   Click the Outlet TS button and give your new time series a name.  You might name it “Powerhouse” or “Fish Bypass” or something […]
Read More
Weir Equations in HEC-RAS
HEC-RAS has the ability to simulate flow at hydraulic controls in a variety of ways. Bridges, culverts, inline structures, lateral structures, and SA/2D area connections can all act as hydraulic controls.  Effectively, they break up the conservation equations used between cross sections in a 1D reach and/or cells in a 2D area with empirically derived […]
Read More
Read More
Read More
Advanced Rules for Unsteady Flow
This is a great presentation put together by Mr. Steven Piper of the Hydrologic Engineering Center that discusses in detail the use of “Rules” at inline structures.  Dr. Michael Gee forwarded this presentation to me after seeing some discussion on the forum about the use of Rules for inline structures.  Thanks for the suggestion Dr. […]
Read More
Read More
Inline Structure Flow Stability Factor
So many of us know that if you experience instabilities at or near your inline structure, you should bump up the Inline Structure Flow Stability Factor from the default of 1 to the most stable value of 3.  But what is really going on when you do this? Here’s an example of a RAS model […]
Read More
