geometry file | Kleinschmidt
Permanent and Non-Permanent Ineffective Flow Areas
The traditional way of changing non-permanent ineffective flow areas to permanent involves going through each cross section, one at a time, in the cross section editor, selecting Options…Ineffective Flow Areas, and then manually checking which ineffective flow areas to make permanent. This can be long and tedious if you have a lot of cross sections […]
Read More
